rhhollin
Jul 30, 2022Aspirant
RBS50v2 Satellite Router flashing red
One of my two satellite routers has suddenly started flashing red after solidly working for several months. I have tried the factory reset with no change. I have tried using the TFTP solutions sugges...
rhhollin
Aug 01, 2022Aspirant
I tried this approach before I posted my message. The problem is that the suggested solution shows the PC USB card connected to the satellite router as active, i.e. will come up saying "unknown network". In my case, the USB adaptor says that the USB cable is not plugged in, even though it is plugged in. Just to be sure, I have tried connecting with a different USB cable, same result. It appears that whatever corruption occurred in the router firmware makes it appear that the satellite is not connected to the PC. If I can't access the satellite router via USB, I don't see how I can update the firmware, meaning the satellite router is not fixable.
Aug 02, 2022Guru - Experienced User
You can't do it over usb. You need to use the ethernet connection on the satellite to your computer.
- plemansAug 02, 2022Guru - Experienced User
Did you watch the video that walks you through it?
- rhhollinAug 02, 2022Aspirant
Sorry, incorrect description. I was using ethernet, not USB. I did watch the video and the key difference is that my ethernet adaptor shows that there is no cable attached to the satellite router, instead of showing "unknown network" as in the video. There is in fact an ethernet cable connecting the PC and the RBS50 and changing to a different ethernet cable makes no difference. Since the ethernet adaptor can't see the RBS50, I see no way to upload new firmware to the device.
Did you try nmrpflash? its a little easier with timings.
Also, try a different pc/laptop. Maybe the adapter has issues with the static settings you need to use.
