ris
Sep 12, 2020Aspirant
RBS50v2 satellite stuck on 2.4Ghz.
Hey, so recently I noticed a huge dip in performance in the upstairs of my home, where the RBS50v2 satellite is. I pay for 200 Mbps from WOW (I know its a terrible ISP). I get around 220 Mbps downsta...
- Sep 13, 2020
Power cycling and moving the satellite further away seemed to fix the issue!
CrimpOn
Sep 12, 2020Guru - Experienced User
ris wrote:I did some digging and found out the cause is most likely that the satellite is on a 2.4Ghz channel instead of its dedicated 5Ghz channel.
Perhaps it would be worth confirming this conclusion. Open a web browser to http://orbilogin.net/debug.htm
When the page opens, check the box: "Enable Telnet"
Open a telnet program and connect to orbilogin.net
(Windows has a telnet clienet that can be enabled from the Control Panel, Programs and Features, Turn Windows Features on or off.
I use the free program PuTTy. There are telnet programs for Mac, Apple, and Android)
Enter this command: satelliteinfo wifi
The output should look something like this:
root@RBR50:/# satelliteinfo wifi
"mac address" : "A0:04:60:xx:xx:xx",
"hop" : "1",
"bridge mac" : "A0:04:60:xx:xx:xx",
"backhaul conntype" : "5GHz",
"backhaul rssi" : "-71",
"backhaul macaddress" : "A0:04:60:xx:xx:xx",
"backhaul phytxrate" : "975",
"backhaul phyrxrate" : "780",
"backhaul parentmac" : "A0:04:60:xx:xx:xx"
Notice my Orbi says the backhaul conneciton type is "5GHz" and the transmission/reception rates are 975 and 780.
What does your Orbi report for the backhaul connection?
