Cherishwit's avatar
Nov 15, 2020
RBS50v2 satellite will not connect with my RBR20 router are they incompatible?
  • plemans's avatar
    It should work.
    What issues are you having with the syncing?
    What firmware is on the satellite?
    What firmware is on the router?
    • Cherishwit's avatar
      Cherishwit
      Tutor
      I have been using the Orbi App to add the new satellite but it just can't see it.
      I power up the satellite then press sync as instructed but it says "Satellite not found".
      Firmware version on the RBR20 is V2.5.1.16
      App version 2.6.4.1265
      Until I can connect with the RBK50 Satellite I don't know anything about it.  It was bought from Ebay and came boxed but secondhand.
      • FURRYe38's avatar
        What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite.
        Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Here you can find the FW information
        I recommend installing near or same verson as whats loaded on the RBR. There is a v16 version for RBS50s
        Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the RBR.
