edski2023
Mar 04, 2023Aspirant
RBS50v2 satellite with bad firmware
I bought a used RBS50v2 satellite online and when trying to add it to existing network it blinks red and flashes white which indicates bad firmware. How do I download and fix firmware if it will not ...
CrimpOn
Mar 04, 2023Guru - Experienced User
Some people have reported success using TFTP or nmrpflash:
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
https://github.com/jclehner/nmrpflash
The process is sort of technical and can be a challenge.
edski2023
Mar 06, 2023Aspirant
Thanks for the reply. Is there a Mac-compatible version of the TFTP software?
- FURRYe38Mar 06, 2023Guru - Experienced User
Try this?
- michaelkenwardMar 06, 2023Guru - Experienced User
