mnagie97
Jun 02, 2022Aspirant
RBS50v2 won't connect
One day last week this satellite would not connect to the router. It has been working fine for a long time. I do see my other satellite with no problem. I have reset it to defaults and even put th...
KevinLiT
Jun 02, 2022NETGEAR Moderator
Hello mnagie97,
Welcome to the NETGEAR Community!!
I understand that you are only able to see one of the satellites connected to your network.
Which firmware are you on?
What is the model version of the satellites synced to your RBR50?
Best,
Kevin
Community Team
- mnagie97Jun 02, 2022Aspirant
V2.7.4.24
I don't see a version. I just see RBS50
- KevinLiTJun 03, 2022NETGEAR Moderator
Hi mnagie97,
Please check your PM.
Best,
Kevin
Community Team
- mnagie97Jun 03, 2022Aspirant
I initially contacted Netgear support and they were no help at all.
They just gave up after trying after trying the standard troubleshooting techniques.
They told me to contact the place I bought this from.
Is this a different support?
