steve8411's avatar
steve8411
Apprentice
Aug 13, 2020
RBS50Y - Any firmware in the pipeline since 2.3.5.32
I have an RBS50Y attached to my RBR50 +2 sats wifi network set up in AP mode.
The RBS50Y seems to disconnect almost monthly like clockwork.
Cant say I could nail it down to router firmware or the RBS50 firmware but I tend to think the latter as I downgraded the router and the issue continues.
So I'm hopeful there may be a firmware fix ...
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi steve8411,
    We currently do not have a beta firmware for the RBS50Y. I'll reach out to our product teams to possibly get an ETA on the next firmware release.
    Christian
    • steve8411's avatar
      steve8411
      Apprentice
      Anything new on this?
      The same model just received another update for use with Orbi Pro models..
      Bug Fixes:
      • Fixes a DNS problem that intermittently causes loss of connectivity
      • Fixes the issue where MAC ACL entries can be lost
      • Fixes the issue where the third radio can stop working after Dynamic Frequency Selection (DFS) detects radar presence on a channel too many times
      • Fixes the issue where the Insight app or Insight Cloud portal show incorrect information in the device dashboard page when there are multiple attached devices
      • Fixes the issue where the password can be recovered only if the user name is 'admin'
      • Updates the HTTP Certificate
      This seems like some applicable fixes that may solve my problem.
      Can we get a version compatible with the standard ORBI rather than the Pro?
    Cant say I could nail it down to router firmware or the RBS50 firmware but I tend to think the latter as I downgraded the router and the issue continues.So I'm hopeful there may be a firmware fix ...
    How far away is the RBS50Y from the closest sat or router? Have you tried resetting  and re-pairing the RBS50Y, since the RBR50 firmware downgrade?
