Winco
Jan 28, 2019Tutor
RBS50Y - Outdoor Mode vs Indoor Mode
Has anyone had experience and played around yet with these two settings to see if they get better speeds and connectivity with either one on/off? This setting option is accessable via the Orbi mobile...
CrimpOn
Jan 28, 2019Guru - Experienced User
Interesting that the User Manual does not mention this setting:
http://www.downloads.netgear.com/files/GDC/RBS50Y/RBS50Y_UM_EN.pdf
The product exists to be mounted "outdoors". Hard to imagine what this option could be about. Is it present in the web interface as well as the Orbi mobile app?
- WincoJan 28, 2019Tutor
Yes. It is present in the web interface.
Basic > Attached Devices > Click on The Device Name > Location > Outdoor or Indoor
I'm not surprised the User Manual doesn't mention it. There is a lot Netgear doesn't mention about their products - hence the need for this online community.
- CrimpOnJan 28, 2019Guru - Experienced User
(I do not have one of these units) Under Attached Devices->Device Name, is this a binary choice (indoor/outdoor) or is it a field that could be entered by the user? (for example, you could type in "Patio", "Barn", "Gazebo", or whatever) My experience with the "Attached Devices" page is a lot of the fields are descriptive that may be of value to the viewer, but have no obvious impact on how the Orbi performs. The "orbi_dev_name" and "orbi_dev_name_ntgr" are fields that get shown on the web page, but as far as I can see they have no bearing on performance. i.e. I can change any of them to whatever I want and the Orbi still "does what it does". The only thing that seems to change is what appears on the Attached Devices page.
Maybe you could set it to "Indoor" for a day and "Outdoor" for a day and see if you notice any difference?
It is a 'radio button'. You have to choose either one or the other. It is different to the editable name field which you can rename the device e.g. "Patio", "Barn", "Gazebo", or whatever.
I have configured mine to outdoor, as it is, well, outdoors!
- FURRYe38Jan 29, 2019Guru - Experienced User
Maybe a forum moderator can post about this feature:
