Winco
Jan 29, 2019Tutor
RBS50Y - Outdoor Mode vs Indoor Mode
Has anyone had experience and played around yet with these two settings to see if they get better speeds and connectivity with either one on/off? This setting option is accessable via the Orbi mobile...
- j1nMar 23, 2019ApprenticeAny word on if this was solved or not? I have the RBS50Y as well & I’d like to know the outcome of this issue. Thanks, j1n
- schumakuMar 23, 2019Guru - Experienced User
j1n wrote:
Any word on if this was solved or not?This is not an issue - much more it's a question about a configuration option, probably introduced after the User Manual was composed, probably as a part of the certification e.g. for Canada or Europe, where certain 5 GHz channel ranges are not allowed for outdoor usage. Amazing Netgear was uanable to answer this 8-/
