Winco
Jan 28, 2019Tutor
RBS50Y - Outdoor Mode vs Indoor Mode
Has anyone had experience and played around yet with these two settings to see if they get better speeds and connectivity with either one on/off? This setting option is accessable via the Orbi mobile...
mgil1
Apr 13, 2019Star
Having now configured two Orbi RBR50 systems - one with 5 satellites (RBS50) and the latest with 6 (5 RBS50 + 1 RBS50Y Outdoor satellite).
Regarding the RBS50Y Satellite - I think various strands of this post are correct - its a regulatory issue that limits the external band to 2.4GhZ - when set to outdoor mode it will operate as dual band using 5GHz to connect to the RBR50 Router and project 2.4GHz.
I've noticed this actually gives better performance for my configuration as the 5th Satellite is in a Cottage 30 m from the Outdoor Satellite - If the RBS50Y is set in tri-band (Indoor Mode) the cottage satellite locks onto the 5GHz channel and signal reception is poor according to the app -when the RBS50Y is set to out door mode (dual channel) then the cottage picks up the 2.4GHz channel which gives a stronger signal in the app - nor surprising given 2.4GHz will project further than 5GHz.
So In Summary - the option is purely driven by the regulatory requirements - But if you want to use the Satellite as a booster to another satellite opt for outdoor mode (dual band).
Hope this helps
