texashoki
Dec 04, 2022Aspirant
RBS50Y -2CCNAS vs 200NAS
Recently purchased a RBS50Y and noticed that the full product code is "RBS50Y-2CCNAS" whereas everything I see online has the "-200NAS" suffix. Does anyone know the difference and if it is the same p...
texashoki
It is on the bottom of the box-Sorry, not sure how to post picture, does this work?
I am wondering as it has a number to Costco Netgear tech support if maybe this was the Costoco version?
CrimpOn
Dec 04, 2022Guru - Experienced User
The bar code is correct: https://www.barcodelookup.com/606449140545
Says RBS50Y-2CCNAS plain as day.
This appears to be the original model that was not compatible with the WiFi6/6E products.
I'm sure you searched Netgear's web site and the general internet as I did..... and got nothing!
- texashokiDec 04, 2022Aspirant
You are correct, I got absolutely nothing doing a search!
Thank you for your help, you gave me more than I found otherwise. The webpage you linked gave Release Date: 2022-11-14, so it appears to be a newer model or am I understanding that incorrectly?
I mainly want to make sure that it will work identically to the RBS50Y-200NAS as I will be using it with a RBK50-100NAS system.
- CrimpOnDec 04, 2022Guru - Experienced User
2014 is about as "early" as an Orbi can be. I think this is the "gen 1" satellite that works only with Orbi as a "satellite" (does not work with any other model or brand of WiFi router) With an RBR50, you should be fine.
- texashokiDec 05, 2022Aspirant
Crimpon,
I appreciate your help and information, but I have a question if I am misunderstanding/missing something. In your latest reply you say that the date is 2014 and it is an early version. On the barcode url you sent, it shows Release Date: 2022-11-14. Am I reading that wrong (I am interpreting it as November 11, 2022) or is there another reference to date that I am missing? From that release date, I thought it was most likely the latest release instead of an earlier one?
Again, appreciate all the help and replies, you have already helped me get more information than I was able to dig up.
