texashoki
Dec 04, 2022Aspirant
RBS50Y -2CCNAS vs 200NAS
Recently purchased a RBS50Y and noticed that the full product code is "RBS50Y-2CCNAS" whereas everything I see online has the "-200NAS" suffix. Does anyone know the difference and if it is the same p...
Dec 05, 2022Guru - Experienced User
It should work fine with your setup. You can mix v1 and v2 of the AC orbis without issue (done it before). Good thing about buying it from costco though is if you have issues, they have a super generous return policy 🙂
CrimpOn
It's because I'm a doofus and cannot read dates. Geez.
And... My guess is that your initial hunch was correct: a part number specific to Costco.
(With a 24/7 technical support phone number!)
