jeffshap's avatar
jeffshap
RBS50Y discontinued
It seems Netgear has discontinued its outdoor Orbi satellites. Does anyone know of a replacment that will work with the ORBI system?
  • plemans's avatar
    I don't know of any currently being released. The secondary market might be your best bet.
    I've also seen others use weatherproof containers (with proper venting) and simply use a standard satellite. In certain instances, it was actually better than the rbs50y's weatherproofing
    • jeffshap's avatar
      jeffshap
      By "Others" do you mean companies that make an outdoor satellite that works with ORBI?
      • CrimpOn's avatar
        CrimpOn
        Netgear only released one Orbi device rated for outdoor use (RBS50Y) and it will operate as an Orbi satellite only with the original 802.11ac Orbi products.  (not any of the AX or Pro models).
        Since the only way it can be connected to something besides the original 802.11ac product is as a WiFi Extender (not as a satellite), then any WiFi Extender from any company will do the same thing - "extend".  Many companies make WiFi access points rated for outdoor use.
