HenkD
Aug 10, 2024Aspirant
RBS50Y doesn’t connect to RBR20
I recently bought a second-hand outdoor Orbi RBS50Y. I want to connect it to my Orbi RBR20, which already has 3 indoor satellites connected to it. But the connection fails every time. What I have alr...
- Aug 12, 2024
What happens if you set the RBR20 to router mode temporarily and then try to connect to the RBS50Y to the RBR20...
I presume that you have done a factory reset on the RBS50Y and setup from scratch...I'd turn OFF all other connected RBS while you work with the Y RBS. Have the Y RBS in same room as the RBR.
What is the brand and model# of the host router the RBR20 is connected to in AP mode?
How is the RBR20 configured for AP mode? Static IP or Dynamic IP?
Aug 10, 2024Guru - Experienced User
What firmware is on the RBS50Y and on the RBR20?
- HenkDAug 11, 2024Aspirant
The RBR20 is up to date. I can see that in ‘orbilogin’. I can’t see that for the RBS50Y because I can’t connect to it. Any tips on how to update the RBS50Y as a standalone?
- FURRYe38Aug 12, 2024Guru - Experienced User
- HenkDAug 12, 2024Aspirant
After switching to router mode I lost all connection to my Orbi system. Logging in with orbilogin.com does not work anymore. HELP! How can I reconnect / set it back to how it was!?
