HenkD
Aug 10, 2024Aspirant
RBS50Y doesn’t connect to RBR20
I recently bought a second-hand outdoor Orbi RBS50Y. I want to connect it to my Orbi RBR20, which already has 3 indoor satellites connected to it. But the connection fails every time. What I have alr...
- Aug 12, 2024
What happens if you set the RBR20 to router mode temporarily and then try to connect to the RBS50Y to the RBR20...
I presume that you have done a factory reset on the RBS50Y and setup from scratch...I'd turn OFF all other connected RBS while you work with the Y RBS. Have the Y RBS in same room as the RBR.
What is the brand and model# of the host router the RBR20 is connected to in AP mode?
How is the RBR20 configured for AP mode? Static IP or Dynamic IP?
HenkD
Aug 12, 2024Aspirant
I don't know what I did but I could reconnect to the RBR20. It was still in ROUTER mode. After restarting de RBS50Y the router was able to find the satallite. So happy! Thanks for your support!
Aug 12, 2024Guru - Experienced User
Good to hear.
If you need AP mode back on the RBR, can set it up using this process if needed.
Or you can keep the RBR in router mode and use the host routers DMZ for the RBR to help avoid NAT issues.
