darrenplumb
Nov 25, 2020Aspirant
RBS50Y Firmware Canada
Hi There, I live just outside Toronto and have a RBS50Y (bought in the US) Outdoor running on my system. Suddenly it stopped working and would not update. I have done a factory reset of my system and...
Nov 25, 2020Guru - Experienced User
Find all different variences of FW for RBSY here:
https://www.netgear.com/support/product/RBS50Y.aspx#download
- darrenplumbNov 25, 2020Aspirant
Thanks for your feedback. I did see that site earlier. Just wasn't sure which one I should use. Setting this stuff up is not my area of brilliance.
- FURRYe38Nov 25, 2020Guru - Experienced User
If you have the RBSY connected to a Orbi home model system, then I believe what you have is correct. If you have a Orbi Pro, the use the Orbi Pro version for the RBSY. If your using a non NG wifi router, then you'll need to use the Extender mode FW on the RBSY.
- darrenplumbNov 26, 2020Aspirant
Thank you for you assistance. I appreciate that
