sccnyy23
Oct 23, 2018Tutor
RBS50Y Firmware mismatch with RBR50 and RBS50
I have having connection issues with my Orbi RBS50Y outdoor satellite. I also have the RBR50 Router and RBS50 Satellite that are working fine. I noticed there is a firmware discrepency between the ...
st_shaw
Oct 23, 2018Master
The RBS50Y firmware typically lags behind the RBR50. The hardware for the Y is different (no Ethernet ports plus LED lights) so the firmware is not exactly the same. The firmware does not need to match out to the last digit. As long as they are all on v2.2.1.X, you should be fine. Whatever issues you are having are not likely due to firmware mismatch.
If you describe the connection issues in more detail, perhaps someone can help you.
sccnyy23
Oct 23, 2018Tutor
Thanks st_shaw...I will try to re-sync again and reboot to see if that helps. I have changed nothing in the architecture and never had issues prior, until i noticed the firmware mismatch when investigating. I thought i had read somewhere that keeping all constituents on the same FW versions is ideal to avoid issues. If re-boot/re-sync does not correct, I will describe further the connection issues.
- FURRYe38Oct 24, 2018Guru - Experienced User
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Something to try as well.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
