sccnyy23
Oct 23, 2018Tutor
RBS50Y Firmware mismatch with RBR50 and RBS50
I have having connection issues with my Orbi RBS50Y outdoor satellite. I also have the RBR50 Router and RBS50 Satellite that are working fine. I noticed there is a firmware discrepency between the ...
sccnyy23
Oct 23, 2018Tutor
Thanks st_shaw...I will try to re-sync again and reboot to see if that helps. I have changed nothing in the architecture and never had issues prior, until i noticed the firmware mismatch when investigating. I thought i had read somewhere that keeping all constituents on the same FW versions is ideal to avoid issues. If re-boot/re-sync does not correct, I will describe further the connection issues.
Oct 24, 2018Guru - Experienced User
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Something to try as well.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
