MaBell
Aug 06, 2019Aspirant
RBS50Y Firmware Upgrade Fails
Currently have the Orbi Pro with 2 additional satellites, hardwired backhaul. I purchased 2 Netgear Orbi Outdoor Satellite RBS50Y units that had the following firmware: V2.3.0.28 It is suggesting ...
MaBell
Per suggestion, I have tryed loading the firmware file via Fire Fox with no luck. The same outcome, overwrites the firmware to V0.0.0.0. Was able to reload the earlier version V2.3.0.28
- FURRYe38Aug 07, 2019Guru - Experienced User
I would open a support ticket here and get some help from NG:
https://www.netgear.com/mynetgear/registration/login.aspx
MaBell wrote:Per suggestion, I have tryed loading the firmware file via Fire Fox with no luck. The same outcome, overwrites the firmware to V0.0.0.0. Was able to reload the earlier version V2.3.0.28
