MaBell
Aug 06, 2019Aspirant
RBS50Y Firmware Upgrade Fails
Currently have the Orbi Pro with 2 additional satellites, hardwired backhaul. I purchased 2 Netgear Orbi Outdoor Satellite RBS50Y units that had the following firmware: V2.3.0.28 It is suggesting ...
MaBell
Per suggestion, I have tryed loading the firmware file via Fire Fox with no luck. The same outcome, overwrites the firmware to V0.0.0.0. Was able to reload the earlier version V2.3.0.28
Aug 07, 2019Guru - Experienced User
I would open a support ticket here and get some help from NG:
https://www.netgear.com/mynetgear/registration/login.aspx
MaBell wrote:Per suggestion, I have tryed loading the firmware file via Fire Fox with no luck. The same outcome, overwrites the firmware to V0.0.0.0. Was able to reload the earlier version V2.3.0.28
