JREWING's avatar
JREWING
RBS50Y firmware V2.3.0.28 +2 x RBS50 firmware V2.3.1.44 Problems all three is offline and is Magenta
Hi,   I am having problems, since 2 days back now, installed the netgear armor Bitdefender, and it feels like the problems started after that. i can only update the router now with new firmware, ...
  • JREWING's avatar
    JREWING
    Apr 25, 2019
    All worked fine I did a factory reset , will not install the bitdefender until it works.
