JREWING
Apr 24, 2019Aspirant
RBS50Y firmware V2.3.0.28 +2 x RBS50 firmware V2.3.1.44 Problems all three is offline and is Magenta
Hi,
I am having problems, since 2 days back now, installed the netgear armor Bitdefender, and it feels like the problems started after that. i can only update the router now with new firmware, ...
- Apr 25, 2019All worked fine I did a factory reset , will not install the bitdefender until it works.
Apr 24, 2019Guru - Experienced User
Should everything come back online and ready, be sure to do a back up configuration to file on the RBR so if something happens again and a reset is needed, you can re-load from back up and save time. :smileywink:
