Furoco
Jun 23, 2020Tutor
RBS50Y Power lead length
Does anyone know the length of the power lead: (a) Orbi connector to power block (b) Power block to UK plug I want to mount this on an outside wall and pass the DC power line through the wall t...
Jun 23, 2020Guru - Experienced User
Would be easier to just run a power extension cable out to the power adapter for the RBSY.
- CrimpOnJun 23, 2020Guru - Experienced User
I may be incorrect, but my understanding of the electrical code is that 120volt electricity cannot be run through walls, whereas low voltage wires can. Building codes are such a nuisance!
- FURRYe38Jun 23, 2020Guru - Experienced User
Well for most U.S. buildings v120 is already in walls. :smileytongue:
For an extension to be used, one would need a outdoor power outlet if this is for a RBSY which is out door. Thus a extension could be used. Cable placement and management would be good to include as well. :smileywink:- CrimpOnJun 23, 2020Guru - Experienced User
Yes, I think that is exactly the problem. With no electrical outlet close to the satellite location, it is a choice of (a) install a code compliant electrical outlet on the outside, or (b) run a low voltage cable through the wall from an indoor electrical outlet and stick some silicon calk in the hole.
