sclawrenc
Aug 09, 2024Apprentice
RBS50Y Serial Recovery Options for Suspected Corrupted Firmware
I have a RBS50Y that is flashing red (corrupted firmware) upon boot, and will not reset no matter what I try (30, 30,30), several reboots... still flashes red. I connected a USB to Serial adapter a...
CrimpOn
Aug 16, 2024Guru - Experienced User
No idea. I have used the serial interface to copy individual files to a router and use the built-in vi editor to modify files. No clue how to load firmware. Sorry.
sclawrenc
Aug 16, 2024Apprentice
Thanks for your reply. Surely Netgear didn't make the RBS50Y without some way to recover corrupted firmware in the absence of an ethernet port!? With a $500 retail price, there has to be a way to recover the firmware in case of corruption, right? 😉
- CrimpOnAug 16, 2024Guru - Experienced User
I agree there probably are methods to load firmware on the product using the serial interface. Developers work will all sorts of devices which have no Ethernet port. (Come to think of it, I have never opened up any of my cheap IoT gizmos to see if they have serial interfaces in them. Hmmm. Probably not. They may have to physically install a new chip.)
My guess is that one of these developers could explain the differences in the various types of devices, Broadcom vs. Qualcom chipsets, etc. etc. For the rest of us, the learning curve could be YEARS.
- sclawrencAug 16, 2024Apprentice
I'm not sure with this particular device since I don't see any u boot commands that jump out at me such as loady or similar that allow loading firmware over serial. Are there any developers or Netgear employees that might be able to at least give me a hint? I think a hint will help me figure it out and I can do the necessary homework.
In eight years on the Community Forum, I have never seen a post from anyone identified as a Netgear software engineer. My imagination is that their time is allocated to assigned projects (probably in 15 minute increments) and browsing a user forum is not one of the assigned tasks. (where's the $$$ in that?) The actual Netgear employees participating in the forum are forum moderators tasked with keeping the forum operating.
I am still at the stage of being annoyed with Netgear because the GPL source code they publish does not allow customers to compile the firmware (as my reading of the GPL says it should).
