yellowsubmarine
Nov 09, 2023Aspirant
RBS50Y stand broke
My stand broke and I cannot find a replacement on eBay or Amazon or anywhere. Any tips?
Since this model is out of production and support, you'll need to look into making something as an alternative or maybe try to glue the parts back together if thats something that can be done. Or try to mount the case to something on a wall or post or something that can stand up and you can mount the case to.
Good Luck.
If Super Glue doesn't work, the wall mount bracket could be screwed to a home made stand.
https://www.downloads.netgear.com/files/GDC/RBS50Y/RBS50Y_QSG_EN.pdf
