Mellod
Sep 22, 2020Aspirant
RBS50Y Will not sync, blue light is solid but states " failed to connect "
Hi,i cannot tel which Firmware is on RBS50Y, trying to sync it with RBR50 ( they were synced until a few days ago. I need to know how to check Firmware and update it on RBS if needed.
Sep 22, 2020Guru - Experienced User
Remove the Previous RBSY connection seen on the RBRs web page. Reboot the RBR. Factory reset the RBSY and use the sync buttons to re-sync. I would do this with the RBSY place in the same room as the RBR...
Mellod
Sep 23, 2020Aspirant
Thank you, I tried this several times, same
results, failed to connect. I also rebooted modem, and router.
- MstrbigSep 23, 2020Master
results, failed to connect. I also rebooted modem, and router.If you are absolutely sure you factory reset the Orbi yard, and you tried pairing it in the same room as the router, but are still failing, it is possible that the device is defective.
- MellodSep 23, 2020AspirantThank you, yes I'm positive, the power light went magenta and flashed.
If you have not yet, try this method:
When router is powered on, press the reset button and hold for 30 seconds. (Use a paper clip or something sharp)
While holding the reset button pressed, unplug the power of the router and hold the reset button for 30 seconds.
While still holding the reset button down, turn on the power to the unit again and hold for another 30 seconds.
