Mellod
Sep 22, 2020Aspirant
RBS50Y Will not sync, blue light is solid but states " failed to connect "
Hi,i cannot tel which Firmware is on RBS50Y, trying to sync it with RBR50 ( they were synced until a few days ago. I need to know how to check Firmware and update it on RBS if needed.
Sep 22, 2020Guru - Experienced User
Remove the Previous RBSY connection seen on the RBRs web page. Reboot the RBR. Factory reset the RBSY and use the sync buttons to re-sync. I would do this with the RBSY place in the same room as the RBR...
