MightyT
Dec 17, 2021Star
RBS50Y Will not sync with RBR50
I bought an Outdoor Orbi in July. Have an Orbi 5 RBR50 Router with a Satellite and a Voice Satellite. All worked well. Added the Outdoor Orbi just fine. Recently it just disconnected and just flashes ...
Dec 20, 2021Guru - Experienced User
What Firmware version is currently loaded on the RBR and RBSY?
Did you try to sync the RBSY in same room as the RBR with all other RBS turned OFF?
What mode is the RBSY operating on? Orbi mode or Extender mode?
MightyT wrote:
I bought an Outdoor Orbi in July. Have an Orbi 5 RBR50 Router with a Satellite and a Voice Satellite. All worked well. Added the Outdoor Orbi just fine. Recently it just disconnected and just flashes white. I had other problems with my router(page 400) and had to factory reset the mesh. In the process the other two satellites synced up, but the Outdoor Orbi will not connect. I factory reset it, I tried syncing from the app and web, changed modes to ensure it was in Orbi mode, and have it sitting feet from the router. Nothing! It will not connect or become solid white. I even tried generating new keys. Any help would be app!
- MightyTDec 20, 2021StarWhat Firmware version is currently loaded on the RBR and RBSY?
- The RBR is 2.7.3.22
- I can’t tell you what the RBSY is because it won’t connect an I have factory reset it like I did the router and other two satellites, which connected fine again.
- It’s a Motorola SURFboard SB6141
-Yep
- It’s in Orbi mode. I even checked by switching it back and forth.- FURRYe38Dec 20, 2021Guru - Experienced User
Unfortuneately the RBSY doesnt' have a ethernet port or it would be ease to get access.
Only idea I can come up with is to try setting the RBRs WPA security temporairily to NONE and see if the RBSY will connect. I presume if not, then something has happened to the RBSY or between the RBR and RBSY. Possible FW is out of sync or way off.
You might try downgrading the FW on the RBR to something older to see if the RBSY will connect. Maybe v104.
With no ethernet port on the RBSY it makes it hard to trouble shoot additional problems. But then it wouldn't be outdoor qualified if it had a ethernet port.
