BobArnett
May 22, 2023Tutor
Rbs50y won't sync with rbr50
I have an RBR50 router with five RBS50/RBS50Y satellites. I am trying to add another RBS50Y to the system but cannot get it to sync. I'm a little scared that I might obliterate my system if I follow s...
May 23, 2023Guru - Experienced User
I've seen a user on here with 8 satellites so you aren't going to obliterate anything.
But like CrimpOn says, sometimes, you have to power off the other satellites to get additional ones connected.
- mphreysD1May 26, 2023Aspirant
plemans wrote:I've seen a user on here with 8 satellites so you aren't going to obliterate anything.
Hello, every one i am new here i have same query, plemans i was try as per your reply but no result found some loop error found can you explain how to resolve this error. it's urgent any buddy can help me.
Best regard,
mphreysD1
