BjornMo
Aug 21, 2021Aspirant
RBS750 ax4200 back haul wired out of sync after a while
I have a RBR directly connected to 3 RBS. 1 of the RBS is always out of sync. When I start it up it stated backhaul wired is good, but after a while it goes out of sync. What I've done so far: - U...
CrimpOn
Aug 21, 2021Guru - Experienced User
Is it always the same satellite that goes out of sync?
What if it changes places with one of the other satellites.
Does the problem go with the satellite, or stay with the location?
- BjornMoAug 21, 2021AspirantHi Crimpon,
Thanks for getting back.
Yes, always the same satelitte, even when swapping to other places. The same satelitte has the issue, others work fine on all locations.
The satelitte not working properly is the add on (same model, version rbs750 ax4200) as the others, but the others came with the router.- BjornMoAug 21, 2021AspirantAdding screenshot, where back haul is out of sync
- CrimpOnAug 21, 2021Guru - Experienced User
I was hoping to pin this on the embedded ethernet cable moving inside the wall and opening one of the 8 wires.
Dang.
If the add-on satellite is less than 90 days old, Netgear owes you 90 days of complimentary support. If it is older than 90 days, but less than one year, you can ask for a warranty replacement.
Do I understand correctly that WiFi backhaul also starts off OK and then fails?
