zeta2388's avatar
zeta2388
RBS750 continually drops connection
We have an RBR/RBS750 system (Router + 2 statellites). The satellites seem to be continually dropping the connection. These drops happen frequently, but are short in duration (30s-1min).
Firmware version is: V4.6.5.14_2.0.54
Settings -
AX disabled for 2.4
2.4 GHz channel - 11
5GHz channel - 40
CTS/RTS Threshold is set to 2347 for both 2.4 and 5
One of the satellites also shows backhaul status as poor, but I'm not sure if this is related or could be causing this.
ASK:
1. Solution to the intermitted wi-fi drops
2. Solution to the poor back haul status
Thanks in advance for any help you can provide!!
