cfryer's avatar
cfryer
Tutor
Sep 03, 2021
RBS750 Satellite Appears to Be Restarting or Dropping COnencitons
I have a couple of devices that drop off my network Wi-Fi when I am using one of the RBK753 Satellite connecitons (RBS750).  I cant find any way to see if the RBS750 has indeed restarted.  However, multiple devices drop off at the same time.  Please note that the RBS750 is wired back to the RBR750.
Is there anyway to see uptime on the satellite?  Any way to see any logs from the satelite?
3Same devices do not drop off when they are connected to the RBR750.
Thanks.
1 Reply
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Thank you.
