jcrozat
Feb 07, 2021Aspirant
RBSR0 Satellites showing No Connected Device Found after firmware update
I have 2 Satelittes and a router throughout my 2 level home. And I have all my devices connecting to my router and none connecting to the Satallites after the lates Firmware update. v2.7.2.104. I ...
jcrozat
I've verified in the Iphone App and I also logged into the gateway IP of the router via my web browser. I have close to 30 devices connected devices.
vajim
Feb 07, 2021Master
jcrozat wrote:I've verified in the Iphone App and I also logged into the gateway IP of the router via my web browser. I have close to 30 devices connected devices.
Ok. Forget the app
I too have seen recent screw ups with the pc login. Mine says one of my sats is disconnected. The last time this happened a simple reboot of all, modem and orbi and the problem went away. I may do that at some point, but for now all devices working and the sats have no rim color.
if your devices are working I wouldn't worry but it's your blood pressure.
- jcrozatFeb 07, 2021Aspirant
Just bugs me, the whole point of the Satellites is to spread the device load and improve signal strength. If devices are connecting to the wrong base station then that defeats the purpose and why did I spend the money on a mesh network? It appears to be a roaming issue, but of course we won't get those kind of details on a home solution such as this.
- vajimFeb 07, 2021Master
jcrozat wrote:Just bugs me, the whole point of the Satellites is to spread the device load and improve signal strength. If devices are connecting to the wrong base station then that defeats the purpose and why did I spend the money on a mesh network? It appears to be a roaming issue, but of course we won't get those kind of details on a home solution such as this.
Perhaps...but until you know with 100% accuracy your worry may be in vain
Try the reboot on all then check the pc login
if that does not improve the situation try a factory reset on the whole system
Ok quick update. Some devices have moved to the Satellites, but no all and not what I'd expect. Roaming on these things is concerning. That said I'm also unable to access the web interface of one of my Satellites, so that may be an issue to look at. Thank you for the feedback. I'm going to see if I can find a way to telnet into the device and do some more digging.
