JS142's avatar
JS142
RBW 30 Firmware 2.5.0.4 and 2.6.1.6 files are corrupt
Before and after unzipping firmware downloads for RBW30 versions 2.5.0.4 and 2.6.1.6, the firmware file is labeled as "Recovered File Fragments"  instead of "Disk Image File" that I get when I downlo...
  • JS142's avatar
    Dec 18, 2020
    In file explorer I changed the extension of the unzipped firmware download file from .chk to .img
    then I had to connect to each RBW30 unit individually using their respective IP addresses.  From there I could work through the menus to get to manual firmware update and use the renamed .img file.  The file loaded and updated.
