stevefxp
Mar 16, 2019Apprentice
RBW30 - Firmware 2.3.0.4
I am trying to download version 2.3..0.4 firmware for the RBW30 but it does not download completely. I get a .chk file in the zip from each download location I can find, which means the zip is not co...
- Mar 16, 2019
Try a different browser? IE11 or FF or Opera?
You can try to rename the file extension to from .chk to .img and see if this works.
Mar 16, 2019Guru - Experienced User
stevefxp wrote:
I am trying to download version 2.3..0.4 firmware for the RBW30 but it does not download completely. I get a .chk file in the zip from each download location I can find, which means the zip is not complete. Does anyone have a complete download of this version?
I just tested and it downloaded perfectly. Have you tried a different internet browser? or computer? Clear cookies/cache/etc?
- SxottieMar 17, 2019Aspirant
RBW30 Firmware download is corrupt. The internal IMG update file is in a CHK format. I have downloaded the same file with two different browsers. Please update ZIP file
