stevefxp
Mar 16, 2019Apprentice
RBW30 - Firmware 2.3.0.4
I am trying to download version 2.3..0.4 firmware for the RBW30 but it does not download completely. I get a .chk file in the zip from each download location I can find, which means the zip is not co...
- Mar 16, 2019
Try a different browser? IE11 or FF or Opera?
You can try to rename the file extension to from .chk to .img and see if this works.
ekhalil
Mar 16, 2019Master
I had no problem to download the zip file from the Support site.
I have it in my Dropbox here: https://www.dropbox.com/s/6y2pguadazyt146/RBW30-V2.3.0.4_1.0.5.zip?dl=0
- SxottieMar 17, 2019Aspirant
Your file is also corrupt. Needs to be an IMG file, not CHK.
- michaelkenwardMar 18, 2019Guru - Experienced User
The RBW30-V2.3.0.4_1.0.5 zip file I retreived contained RBW30-V2.3.0.4_1.0.5.chk.
- VegasdealerMar 20, 2019Tutor
Thanks for posting this. Tried to update RBW30 via the app which says firmware is up to date, but shows V2.2.1.210 in the app and not V2.3.04 as well online on my iMac and won't update. Tried changing the file name to an img file, but didn't work on Mac OS MOJAVE 10.14.3
Hopefully, Netgear will change the format, as at lost as what to do.
- FURRYe38Mar 20, 2019Guru - Experienced User
Try using FF or Opera browser on your iMac PC to send the file. The file doesn't need to be changed.
What is the current FW version loaded on the RBW?
