stevefxp
Mar 16, 2019Apprentice
RBW30 - Firmware 2.3.0.4
I am trying to download version 2.3..0.4 firmware for the RBW30 but it does not download completely. I get a .chk file in the zip from each download location I can find, which means the zip is not co...
- Mar 16, 2019
Try a different browser? IE11 or FF or Opera?
You can try to rename the file extension to from .chk to .img and see if this works.
Mar 16, 2019Guru - Experienced User
the .chk file is correct. If you were able to unpack the .zip file and you found the .chk file, this means the .zip file completed the download correctly. Use IE11 or FF web brower too apply the FW update.
- stevefxpMar 16, 2019ApprenticeThis is weird bc the browser based tool tells me it needs a .img file when I try to upload the .chk file.
