DorkiOrbiFW
Apr 25, 2019Apprentice
RBW30 - Issues on Firmware 2.3.0.4
Hello Orbi Community, My system has been running exceptionally well lately until recently. The only unit in my system that is posing an issue is my RBW30 wall plug satellite. My backhaul status is...
- Apr 29, 2019
FURRYe38 wrote:
Whats the distance between the RBR and RBW?
Seen others with RBW issues and not really sure of any good resolution. Confidence in RBWs has been low. Try prior working FW, if that resolves this in time being, then I would file a support ticked and inform NG of issues with v2.3.0.4...
The distance is perfect, as I have never had any issues with the RBW30 (and actually it has been the best satellite of my entire system as I have never had issues until the release of the crappy 2.3.0.4). Although, come to think of it now, I didn't have any issues with that satellite until after I updated my router to version 2.3.1.48. For some odd reason (I HAVE ABSOLUTELY NO EXPLANATION TO), it actually has been stable and reliable for 2 days. I don't know if perhaps it needed time to "adapt and play nice" with my RBR40 running 2.3.0.48.
Who knows?
Apr 26, 2019Guru - Experienced User
DorkiOrbiFW
Apr 29, 2019Apprentice
Who knows?
- FURRYe38Apr 30, 2019Guru - Experienced User
Probably the system stablizing on it's own?
Who knows?
Regards,- DorkiOrbiFWApr 30, 2019Apprentice
FURRYe38 , it must have been, as I have now been rock solid with all of my devices connecting beautifully for 3 days straight now with no issues. I am running all the latest versions for my Orbi router and satellites. I AM HAPPY! :smileyvery-happy:
Regards,- FURRYe38May 01, 2019Guru - Experienced User
Now save off a backup of the system config to file for safe keeping.
Mark your post as solved so others will know.
Enjoy. :smileywink:
