stevefxp
Mar 22, 2019Apprentice
RBW30 - Update Failed
Hello all,
I recently updated my RBW30 to v2.3.0.4. I am noticing that its saying it has a firmware update but the update failed. Anyone seeing this?
Steve
Mar 22, 2019Guru - Experienced User
Are you on Mac or Windows?
What browser are you using?
stevefxp wrote:
Hello all,
Steve
stevefxp
It seems a reboot took care of this!
- FURRYe38Mar 22, 2019Guru - Experienced User
Ah good to hear.
Mark your thread as solved so others will know.
Enjoy. :smileywink:
- guppybeastMar 22, 2019Aspirant
I'm having the same issue, but a reboot didn't solve things. Rebooted the router and the RBW30 and even did a factory reset on the satellite, but still showing "Update Failed" every time, which is preventing the other devices from auto-updating.
Are you using Mac or Windows PC?
Try manually downloading the FW file for the RBW and apply usnig the Manual Update tab.
