stevefxp
Mar 22, 2019Apprentice
RBW30 - Update Failed
Hello all,
I recently updated my RBW30 to v2.3.0.4. I am noticing that its saying it has a firmware update but the update failed. Anyone seeing this?
Steve
stevefxp
It seems a reboot took care of this!
Mar 22, 2019Guru - Experienced User
Ah good to hear.
Mark your thread as solved so others will know.
Enjoy. :smileywink:
- guppybeastMar 22, 2019Aspirant
I'm having the same issue, but a reboot didn't solve things. Rebooted the router and the RBW30 and even did a factory reset on the satellite, but still showing "Update Failed" every time, which is preventing the other devices from auto-updating.
- FURRYe38Mar 22, 2019Guru - Experienced User
Are you using Mac or Windows PC?
Try manually downloading the FW file for the RBW and apply usnig the Manual Update tab.
I'm on Windows - 2.3.0.4 is already installed and working fine - it just seems to think there's an additional update that is failing. I don't see anywhere to download that - if I go to the RBW30 support page, 2.3.0.4 is the latest firmware posted
- Chuck_MMar 22, 2019Mentor
You may also want to power off the satellite you are having issues with, update the remaining ones, and then repower the satellite to see if that allows you to update the firmware.
- WarshockMar 22, 2019AspirantEarly morning my orbi was still ok. Was still able to access internet. All of the sudden the internet got cut off and orbi jus shows steady white light at the top. I tried resetting, restarting but still steady white. I tried following instructions to manually load fw using tftp64 but im stuck when i turn off the router then turn on after 10s i did not get any orange power LED and no flashing. Im stuxk right now
