Tymok
Mar 22, 2021Aspirant
Rbw30 backhaul issue
Hi
I’ve got a rbk30 setup, with the rbw30 wallplug satellite.
When I connect my devices by Wi-Fi directly to my router I get 400/40Mbps. When I connect devices to the satellite a get maximum 72Mbps download.
I’ve restored default settings, tried daisy chain, beam form settings etc, makes no changes.
I’ve Moved the satellite to a place near the router, still nothing. Is this an issue with the latest firmware? Running on 2.6
Are you testing speeds off the 2.4ghz or 5ghz?
2.4ghz is much slower and sensitive to interfernce.
And the orbi devices band steer
- TymokAspirant
I tried 2.4 GHz and 5 GHz.
For tests, I've even changed the name for wla_2nd_ssid to make sure I am connected to the 5GHz SSID.
At 2.4, I get about 120 Mbs on the router and 72 Mbs on the satellite (download speed)At 5 GHz, I get the my provider's maximum speed on the router (400Mps) and still 72 Mps on the satellite.
My smartphone and computers show a connection at 886Mbps, so I think it may be a backhaul problem.
Two of my computers connected to the router at approx. 300 Mbps download speed on 5 GHz with the satalite disconnected.
When I power up the satalite, computers switch to it (better signal strength) and the download speed drops to 72 Mbs. The computers show a connection to satallite with at 866 Mbs. I've tried to move the satalite to the next room, to make the computers connect only through the router, but this doesn't work for me. When I move the satallite even further, then the download speed stars slowly dropping and becomes unstable.
When I get the satallite realy close to my router, 5 to 10 meters with no objects between, maximum download speed is still 72 Mbps
Ping through the satallite is about 3ms longer.
this thread has info on checking backhaul signal rates.
