jkpolack24
Nov 11, 2020Tutor
RBW30 Crippling Certain Devices
I'm having issues with an RBW30 that I added to an exisiting RBR20/RBS20. It seems that certain devices are rendered unusable when they are connected through the RBW30 but not through either of the o...
Nov 12, 2020Guru - Experienced User
What Firmware version is currently loaded on the main Orbi system?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What happens if you turn OFF the RBS and leave the RBW running?
- jkpolack24Nov 12, 2020Tutor
I believe all firmware is the latest release for each device (though I'll repeat that this issue has persisted across a few upgrades now).
RBR20 - 2.5.1.16
RBS20 - 2.6.1.38 (updated within the past couple of days)
RBW30 - 2.6.1.6 (updated last week)
House is ~3400 sqft. Distance is probably between 30-40 feet. The RBS was on ethernet backhaul prior to my recent test. The RBW was reporting good backhaul connection at all locations tested. The devices in question are 15-20 feet line of sight through a window to the RBW30 locaion(s).
When the RBW30 is removed the devices will connect to other access points, further away and show link rates greater than 1 Mbps, but between 10-15 probably due to distance from say the RBR20.
Armor and circle aren't used. Daisy chain has been on, but the devices never connected in daisy chain mode. Fast roaming and ipv6 have been on. 20/40 coexistance has been disabled (turning coexistence on seems to give a general problem with the ring devices that otherwise work when it's off). I tried the short preamble the other day and had no improvment. I can try some testing with the fast roaming, ipv6, and preamble.
Good question on the removal of the RBS and using the RBW only. I have not tried that configuration, but will give it a go later today and report back.
- FURRYe38Nov 12, 2020Guru - Experienced User
Has a factory reset been performed on the RBW since last FW update?
- jkpolack24Nov 12, 2020TutorYes via holding the button until the orange light comes on and have also tried a telnet reset.
Just did a quick test swapping in the RBW30 for the RBS20 and the link rate for the camera went from 72 Mbps (RBS20) to 1 Mbps (RBW30) and now doesn't function. The location of the RBS20 and the RBW30 in this test were identical and both used wireless backhaul.
I can play with the settings more later, but unless there is a setting that woudl explicitly impact the RBW30 then this behavior seems strange.
- jkpolack24Nov 14, 2020Tutor
Tried all the settings changes, individually and in a group and they had no impact. Tried another factory reset on the RBW30 and no impact. When a ring camera connects to the RBW30, the link rate goes to 1 Mbps and the camera does not function. If I unplug the RBW30, the cameras reconnect to an RBR/RBS20 (which is further away) and show a linke rate between 50 and 72 Mbps and work correctly.
One thing I did notice is that when the RBW30 is connect, the Orbi app will sometimes state the 2 satelites are due for a firmware update. When I click the link it says that my current firmware is 2.5.1.16 and that I can update to 2.6.1.6. As stated previously, the firmware on the RBS20 is 2.6.1.38 and the RBW30 firmware is 2.6.1.6, which can be confirmed both on the details listed in the network map of the app and on the web interface.
Does the RBW30 possibly somehow think its still on an older firmware. I've heard of configuration settings getting corrupted also. Is there something more potent than a factory reset?
- FURRYe38Nov 14, 2020Guru - Experienced User
Factory reset is the best and only way to reset and clear out things.
Possible the RBW is just faulty. Something I would return and ether find another one to try. or try something else, like another RBS20 if you can find one...EX7500/7700 work as alternative extenders for Orbi. Just not in a mesh configuration.
Yeah, beginning to think the RBW30 is just a faulty product. This is the second one I've tried. I had to fight Netgear to get an RMA on the first and pay to ship it back. Now I'll be trying to fight for a full refund I suppose. Not a good look for Netgear to be honest. Products meant to work together function completely differently.
