jkpolack24
Nov 11, 2020Tutor
RBW30 Crippling Certain Devices
I'm having issues with an RBW30 that I added to an exisiting RBR20/RBS20. It seems that certain devices are rendered unusable when they are connected through the RBW30 but not through either of the o...
Nov 12, 2020Guru - Experienced User
What Firmware version is currently loaded on the main Orbi system?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What happens if you turn OFF the RBS and leave the RBW running?
jkpolack24
Nov 12, 2020Tutor
Just did a quick test swapping in the RBW30 for the RBS20 and the link rate for the camera went from 72 Mbps (RBS20) to 1 Mbps (RBW30) and now doesn't function. The location of the RBS20 and the RBW30 in this test were identical and both used wireless backhaul.
I can play with the settings more later, but unless there is a setting that woudl explicitly impact the RBW30 then this behavior seems strange.
