beckss1
Jun 02, 2020Tutor
RBW30 disconect after last update
Hi., After last upgrade to version RBW30 V2.5.0.2 and RBR40 V2.5.1.16 sattelite continue disconnect from router. No changes in place it into home. And in past I was resolve this problem with rollba...
Jun 02, 2020Guru - Experienced User
- beckss1Jun 02, 2020Tutor
Could you please explain how I make reset on router.
On sattelite I make reset, but on router I can't familiar with this procedure.
Stas
- FURRYe38Jun 02, 2020Guru - Experienced User
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
