MS34
Dec 29, 2020Tutor
RBW30 Firmware did not auto-update
Received email from Netgear yesterday that firmware updates were available to address security issues on the RBR50 and RBW30. Today, I used the Orbi app on my phone to do the updates. The Orbi app ...
- Dec 29, 2020
Thank you for your guidance! I went through those steps, including unpacking the zip file, which produced a chk file. Logged in as instructed and browsed for my unzipped firmware file (chk) and hit the button to load that to the satellite. That seems to have gone successfully, and now when I look at the firmware levels on both the Admin page thru my laptop, and also via the Orbi app on my phone, they both show the new version 2.6.1.6. And I went ahead and resync'd the satellite with the main router, but wasn't sure if that was necessary. Happy Holidays!
CrimpOn
Dec 29, 2020Guru - Experienced User
MS34 wrote:The download available for the RBW30 is 2.6.1.6. How can I get that version onto the RBW30? Thank you in advance for any assistance!
When the Firmware Update web page fails, another way to update firmware on a satellite is to (a) download the firmware file from the Netgear support site https://www.netgear.com/support/product/RBW30.aspx#download , (b) unpage the "zip" file to extract the firmware file (which if my memory is correct is a "chk" file for the RBW30 rather than an "img" file like all the rest of the Orbi's), then (c) use Firefox to connect to the satellite web page using the IP address of the satellite, i.e. http://<ip of rbw30>, and (d) select the bottom menu item "Update Firmware". It will want you to "Browse" to find that firmware file and upload it.
MS34
Dec 29, 2020Tutor
