Shaks01's avatar
Shaks01
Tutor
Aug 28, 2021
RBW30 Firmware seems to be corrupt
Seems the firmware being provided by Netgear for the sattelites is corrupt -- when i try to manually update the sattelite firmware and download the zip file the contents do not have an IMG file i see release notes and i see a RBW30-V2.6.2.6_1.0.16.chk files -- probably why it keeps failing to automatically update -- the interface is looking for a img file --
  • Went through some of the other posts and connected to sattelites via their IP address and updated through their interface -- hope netgear fixes this soon
    • FURRYe38's avatar
      What file did you send to the RBW that worked? IMG or CHK?
