sarok01
Aug 12, 2022Follower
RBW30 firmware v2.6.2.6 update fails
unable to update my rbw30 firmware to v2.6.2.6. i tried through the app as well as manually. when i download the firmware from the website, it is missing the .img file.
- Aug 16, 2022
Hello Luke1965,
Thank you for your post!
The firmware file for your RBW30 will have the file Extention .chk. There are no firmware files missing from the download link:
https://www.netgear.com/support/product/RBW30.aspx#download
If your RBW30 is on the firmware version 2.6.2.6 the error message "Update Failed" can be disregarded.
Best,
Kevin
Community Team
KevinLiT
Aug 12, 2022NETGEAR Moderator
Hello sarok01,
Welcome to the NETGEAR Community!
Thank you for bringing this issue to our attention!
I will escalate this issue to my team for correction.
Best,
Kevin
Community Team
- Luke1965Aug 16, 2022Tutor
Hi! I also on my RBW30 (with firmware 2.6.2.6) when checking for updates on web orbi page shows “update failed” (and give me also an error on App Orbi IOS Apple on IPhone) meanwhile the other satellite and router RB40 has a response of no new firmware available. I tried rebooting and resetting and downgraded firmware without success! Do you manage to solve this iusse or find a fix? Best regards and ciao from Italy! Luke
