sarok01
Aug 12, 2022Follower
RBW30 firmware v2.6.2.6 update fails
unable to update my rbw30 firmware to v2.6.2.6. i tried through the app as well as manually. when i download the firmware from the website, it is missing the .img file.
- Aug 16, 2022
Hello Luke1965,
Thank you for your post!
The firmware file for your RBW30 will have the file Extention .chk. There are no firmware files missing from the download link:
https://www.netgear.com/support/product/RBW30.aspx#download
If your RBW30 is on the firmware version 2.6.2.6 the error message "Update Failed" can be disregarded.
Best,
Kevin
Community Team
KevinLiT
Aug 16, 2022NETGEAR Moderator
Hello Luke1965,
Best,
Kevin
Community Team
Luke1965
Aug 17, 2022Tutor
Thanks a lot for your suggestion! Best regards
Luke
