LetsGoDevils
May 07, 2018Tutor
RBW30 needs to be unplugged frequently
Good afternoon,
I purchased an RBK33 system a few weeks back and after a strenuous installation using the app, I tried installation via orbilogin.net and think I got everything up and running p...
LetsGoDevils
May 08, 2018Tutor
Hello? Anyone from Netgear going to help? Otherwise I can return this orbi until May 10
- DarrenMMay 08, 2018Sr. NETGEAR Moderator
What firmware version is your main router on and the rbw30?
DarrenM
- LetsGoDevilsMay 08, 2018TutorMain router - 2.1.4.10
Rbw30 - 2.1.3.6 - LetsGoDevilsMay 08, 2018TutorAlso under advanced wireless settings - Enable MU-MIMO is checked and the other 2 are NOT checked (enable implicit beamforming and fast roaming). Should I check those?
I want to get you in contact with support I sent you a PM
DarrenM
