Nova17
Dec 17, 2020Aspirant
RBW30 Poor Backhaul
I'm throwing up the white flag here! To summarize, no matter what I've tried, I'm getting an amber "weak" signal from my two RBW30's. I'm getting very fast speeds at the router location itself on mul...
- Dec 19, 2020
After a factory reset and rolling back the firmware, it seems to have done the trick!
RBR40 router firmware is now V2.5.1.22
Both RBW30 satellites are now V2.5.0.4
All the signals and speeds seem to be working perfectly for the last couple of hours.
CrimpOn
Dec 17, 2020Guru - Experienced User
Is it possible to try different locations that are not "right above" the router, perhaps a bit offset horizontally? There could be something hidden in the ceiling that is blocking the signal (air conditioning duct, plumbing pipes).
Generally, having a satellite very close to another Orbi unit (router or satellite) means that their WiFi signals will overlap and compete.
Most people would consider 10-15' actual distance to be "too close".
Nova17
Dec 19, 2020Aspirant
