vugopuri
Jan 10, 2021Follower
RBW30 problem
I have an Orbi RBW30 connected into a network with a few other satellites as well. Guest network works for the other parts of the network, but not this specific satellite. Was working fine until ...
Jan 22, 2021Guru - Experienced User
What Firmware version is currently loaded the RBW Satellie and RBK system?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
What happens if you turn OFF all RBS and just try to sync the RBW to the RBR?
vugopuri wrote:I have an Orbi RBW30 connected into a network with a few other satellites as well.
Guest network works for the other parts of the network, but not this specific satellite. Was working fine until last night. Reboot of this and the main router did nothing to restore it. It transmits SSID and devices can connect, but there is no connectivity to the internet.
Any advice short of a factory reset? I'm running the latest firmware, and hoping to avoid a reset and start over, so looking for other pointers and if a reset actually works before I get into doing that.
Thanks!
- vajimJan 22, 2021Master
Isn't the RBW30 an extender? How do you know it's not working? What are you using to look at your network?
